Hello everyone!
Check out.
wonderful
http://hoodia.konntespass.de
Hello everyone!
Check out.
wonderful
Replace the manage module solved the proper and it’s back to showing.
Our 2006 Bosch DW (SHU43C05UC) started the long run time symptom this week end. Found this forum, followed the thread and downloads to the classic burnt solder connection on the pcb, just a described. Have run 4 loads since my re-solder; a novice looking job, but all is working now. Thanks for the very good info.
Please replaced our control module and the dishwasher is back to working again. Part was about $125 and installation took no more than 15 minutes. Very simple and easy fix. It might help you determine the problem so you can order the correct part you need.
