Controls Don't Work Duet Dryer
The control panel buttons do not work, faint light on heavy duty. Tried
shutting off breaker overnight, it worked once but no more. No error codes.
Appliance store said user interface or control panel. Would like to fix
myself and order appropriate parts.
— Begin quote from Borgeson;728940
There is a light inside drum, btw.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GEW9250PW1
Sounds like a control board problem (Item 57 in Section 2)
I would check the power to the unit first.
If for some reason L1 to Neutral is low the board will not be powered correctly and will do all sorts of strange things.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
