Dryer noisy
Have a whirlpool dryer that makes alot of noise while drying, kind of like a bearing going out. Not a squeay noise though…just real loud. Any ideas?
Most likely the problem is a worn out drum support rollers and/or an idler pulley. It’s a good time to inspect and replace the drive belt.
  • The drum support roller kit [part]349241T[/part]
  • The idler pulley [part]691366[/part]
  • The drive belt [part]341241[/part]
Here are the breakdown diagrams and Parts for Whirlpool LER4634EQ2 Dryer - AppliancePartsPros.com
The disassembly instructions are attached to the post.
The instructions will be helpful, I will check those items out. Thank you Gene
You are welcome. Keep us posted.
The dryer support roller was the issue, I went ahead and replaced all the parts you mentioned since I was going to be in there anyways. Dryer runs like a dream now…wife very happy…Thanks again.
You are welcome. I’m glad it’s up and running.
Happy wife makes a husband happy!
