Dryer will not start
dryer will not start. control panel is lit up. i can change settings on control panel. but dryer will not start.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED6200SW1
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10054150.pdf
Most likely either the thermal fuse or perhaps the belt switch.
If it is the thermal fuse check/clean your vent system as that is the most commmon cause of it blowing.
