my dryer hont heat up. it turns on but therte is no heat!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137524
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
First try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker. Better yet measure it with a meter should be 240 volts. On this unit if the timer advances in timed dry, you have the 240 as the timer motor uses 240.
Next unplug the unit and check the heating element, the thermal cut-off, the hi-limit thermostat and the operating thermostat.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
