Dryer won’t heat. Has fairly new heating element. Pulled heating element out and it looks good. what could be the problem?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=lea30aw
Could be a number of things but I would start by checking the power.
The motor uses 120 volts while the heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Then I would check the element and thermostats with a meter.
Heater first also checking that it is not grounded.
Then hi-limit and thermal fuses (Items 6 & 8 in Section 7)
Then the thermostat (Item 24 in Section 6)
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
