My dryer wouldn’t run the other day.I pushed the start button and thought I heard something and that was all. I ordered a new start switch but that didn’t solve it.The door switch sounds fine(clicks when pushed down) I watched the video for the thermal fuse;he said the dryer would still run.I read a post on here that said it might not run.what would be my next step.The dryer is in a tight spot so it won’t be easy to get inside to the door switch.
Thank-you
Dan
