dryer won't start
The dryer just stopped working. I pressed the starter button and nothing happens. No buzz, no click no nothing.
We would need the model number to be of any help to you.
Eric
Kenmore 400 is all can see.
That doesn’t help. There should be a label somewhere with model number and serial number. May be behind door.
Eric
Mod - 110.68422700
Ser - MW4154041
Check that you have power at the receptacle. If good, check continuity on the door switch and check operation (continuity when pressed) of the start switch. If good, open control panel and check that you have 120vac to ground on timer switch BU terminal with timer on. If good, remove back panel and check continuity of the thermal fuse on the blower housing. Left side with the two blue wires on it. Report findings.
Eric
Ok will do…thanks
