Kenmore 110.96591220 will not start when start button pushed. Start Button appears good, timer motor runs through cycle, thermal fuse checks, Door switch checks good. Outlet power okay. While reassembling top control panel, gave it one more try and IT WORKED! Finished attaching top control panel, attached vent and tried again - DOES NOT START. Left in run mode while I went to think it over and about 30 minutes later, it started by itself and ran for about two minutes until end of drying cycle shut it off.
I could not find a wiring diagram for this unit so am doing some guessing here.
My reasoning is that the push-to-start relay must have remained closed (activated) for the unit to start.
The motors centrifugal switch must have deactivated so it had the start and run windings in circuit because it started with no problems.
Your thermal fuse must be OK.
All that is really left is the timer.
Also could be a bad connection or wire.
Check that the connectors are properly crimped to the wires especially at the timer.
