Frigidaire model FDP635RFR5
I am not getting any water to the upper rack. I have examined the upper tube and it is clear. I assume that the impeller ,in the circulating pump has warn? What am I looking to replace ? The parts needed? Is there a pump assembly or do I replace the impeller and the gaskets?
It looks like the pump is attached to a motor? Do I have to replace all of this?
