Frigidaire Front Loader Problem
I have a frigidaire Front load washer that is about 3 years old and it is in a rental house. I was brought to my attention that it wasn’t working and when i checked it out there was just a ERR display. I have had no luck clearing it or getting it to work. Any suggestions would be greatly appreciated. I am going to try and find the tech manual tommorow when i go to the house and hopefully that will help. It is behind the front panel?
Thanks ,
Jon
It should be under the top or behind the lower front panel.
If you need more assistance please post a full model number.
Thanks and good luck.
I looked behind the back panel and found no manual. I was able to access the control board and I think I can switch out the board. Is there anything special I should know about it other than unplugging and switching out the plugs? I called a local repair shop and explained the symptoms and they thought it was the control board. The Washer is paused in a cycle and when you touch any button it beeps 3 times and flashes ERR.
Thanks again
You should be able just to unplug each connection from the old board and make the connection to the new board. I still do not know which model you have, and some boards have unique connections so that you cannot mis-connect the board, but even then I would still do it one connection at a time.
I also use anti-static devices when I work with boards, not sure you have to but it doesn’t hurt anything to do it.
Let us know how it turns out.
Frigidaire LTF7000ES0
Ok, good. Here is the service manual for it.
http://frigidaireservicetips.com/pdfs/491_AffinityWasherManual.pdf
Thanks for the quick response. I want to try these tests it just stinks that i have to cordinate with the tennant to work on it. I am guessing it will be the control board.
