An item of clothing is often getting stuck at the same point in the top left of the drum.
A repair guy said it looked like there used to be a foam strip around the top of the dryer front drum bearing. He said he tried to order it but it is no longer made, so nothing can be done.
However, I don’t see any foam strip showing on the parts diagram on the top of the bearing. https://www.geapplianceparts.com/store/parts/ModelSectionParts/DBXR453GV0WW/2/0/0/0/FRONT_PANEL_&_DOOR
I only see part #312 - (GE WE9M15) – the dryer duct felt trap. This goes round the bottom and side of the bearing, not the top, and it doesn’t cross the pinch point.
