GE JDP36 temperature set issue
I’m having an issue with my GE JDP36 oven.
When I try to set the baking temperature or broil, it will appear to start preheating (ex: I enter 350 degrees, the display panel will read 100 degrees as though it is preheating), then w/in about 30 seconds, it shuts off. Power is still on, but the temperature set cuts off and the oven does not preheat.
I’m thinking it has to be in the control panel, and I have the front panel pulled apart. But this is a costly part, so I’d like some advise before trying this. Also, if this is it, I would like to know how complicated this is to replace as it appears all the wires from the new control panel will need to be rewired.
Any help is appreciated.
Thanks!
