Help, No Spin Frigidaire
Front load washer doesn’t complete the final spin cycle. Drains, but no spin. I have read on some threads that you can find an error code, how do I do that?:frowning:
Inside the lower service panel is a set of tech notes that will tell you how to generate error codes. It should also show you how to test the speed/motor control board and the door lock assembly which may be your problem.
We took the lower panel off and there is nothing inside, only a warning sticker. We took the drainage pipe off and there was nothing but sewage smell. Is there any way to get the tech notes from another source?
If you still cannot find them, here is a link to the service manual
http://www.emaservicetips.com/pdfs/490_3cuftHorizontalAxisWasherSM.pdf
