How can we repair a front door lock assembly for a frigidaire washer model # ATFB6000ES1.
Get the part and install it
Frigidaire has really good service manuals, so I would consult the one for your model, and this should be it.
http://frigidaireservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
— Begin quote from sidfink43;362946
Thank you so much that was very helpful.
mari
Great, glad it helped
I can’t access that service manual. Is there another copy? I’m getting a dr code or E41 when I hold down cancel/start button and I want to trouble shoot what I need to do or replace.
Look inside the lower service panel and see if there aren’t some tech notes that will tell you how to interpret the codes and how to do some diagnostics.
Thank you for you fast reply! I see no notes in the lower service panel that would help. I have been the only owner of this machine and I have done all repairs (with help from this forum!) so far, so no technician would have left notes. What next?
