When I depress the thru the door paddle, the auger motor does not turn. In addition, if the refrigerator is ‘on’, it will shut off and the light goes dim. After releasing the dispense paddle and hear the ice door close, the light returns to full intensity and the refrigerator comes ‘back on’. I was planning on replacing the motherboard due to the hi-pitched whine it started making, but wondered how to test to determine if the motherboard is a cause for this problem as well. Thanks for help. Ty
The main control board is the culprit. No doubts about it and it does not need any more tests.
- The main control board AP4436216
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5226993
Thanks Gene, I have ordered the part and look forward to resolving the issue!!
You are welcome. Keep us posted.
You are welcome. I’m glad you were able to fix it.
Thank you for the feed back.
