The dryer starts and runs. It does not heat or time out.
Here is your wiring diagram, see the attachment.
If the timer does not advance in both auto and timed dry modes, odds are you have a power problem.
In timed dry the timer mpotor runs directly off the 240 volts through Timer Switch 0 WB/TM contacts. The heater also runs off of the 240 so if both are not working the first thing to check is the power,
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If it does advance in timed dry then the first thing to check would be the heating coil.
Should be about 10 to 12 ohms.
