Symptom: Dryer has no heat.
Replaced all sensors and heating element. Heating element was original problem of no heat. Broken coil. Started dryer and after couple of minutes of heating first thermo fuse blew (no continuity). Checked all wiring and sensors. All good. Replaced thermo fuse and it blew again (no continuity). Run for about3-4 minutes, no problems. Tenant put a load of clothes in and about 10 minutes into drying, no heat again. Happened both times with thermo fuse.
What would cause a thermo fuse to continialy blow? High temp sensor was replaced even though original one checked out good.
Any one come across this problem? Not sure what to do.
On most units there are 2 thermal fuses.
The one on the blower they call a thermal fuse, it kills power to the unit.
The other on/near the heating element, they call a thermal cut-off. This is the one I think you replaced as you said there was just no heat so below is my normal response for problems with this fuse (cut-off).
Check the heating coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off…
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut)
