Kitchen Aid front panel pulling away from unit
Hello,
The panel to the unit has lost a fastener in one corner, and it is pulling away from the unit. It is as though it is two panels being brought together. It appears there was a hidden fastener of some sort that simply slipped into a hole on one of the panels that aligned to a hole on the other panel, then pushed together for a ‘permanent’ fit. I can’t get behind either hole to put a nut/bolt. Can someone guide me on where to find a replacement fastener? It didn’t show up on the parts list. Thank you all, Ken
