Hi; we are trying to fix our oven and we are trying to locate a diagram of this oven so we can replace the thermometer. Does anybody have a diagram of this oven or one similar that they can share? It would be much appreciated!!
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=25915
Which part did you call "thermometer"?
I am a gal trying to help my grandpa fix his oven; he was an electrician back in the day and is determined to replace the thermometer. I will ask him in the morning for more information.
It’s the oven THERMOSTAT that we are trying to locate on the diagram!
What exactly is wrong with the oven?
There is no any oven thermostats in your range. The oven temperature controls by the the electronic control board aka a clock/timer. Unfortunately this part is no longer available. Looks like it’s time for a new range.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=25915&diagram_id=748363
Gene said:
There is no any oven thermostats in your range. The oven temperature controls by the the electronic control board aka a clock/timer. Unfortunately this part is no longer available. Looks like it’s time for a new range.Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=25915&diagram_id=748363
Well, this is bittersweet news! Thanks for your time, Gene! I really appreciate it.
