maytag neptune bearings
When my maytag neptune goes into spin,it is extremely loud. I discovered that this was caused by bad bearings in the back of the drum. How can these be changed out?
[SIZE=3]See [[FONT=Times New Roman][SIZE=3]NEPTUNE HELP SONG[/SIZE]](http://www.neptunebearing.com"]NEPTUNE BEARING[/URL] for the replacement bearings and seal kit. You can also rent a slick tool kit to help you change your bearings. The tool rental also includes use of a DVD that shows Neptune disassemble, bearing swap and seal kit installation.
[/SIZE][/FONT] [SIZE=3]While I have your attention…[SIZE=3]NEPTUNE HELP[/SIZE] Have you changed your door latch wax motor yet? Please see [/SIZE][SIZE=3] for details to prevent a control board failure. Note: If you own an earlier MAH3000 Neptune then you will have (2) more wax motors in the soap dispenser that should be replaced as well. I offer a (2) pack of wax motors just for the earlier MAH3000’s.[/SIZE][FONT=Times New Roman][SIZE=3]
[/SIZE][/FONT] [SIZE=3]Check out the new funny Neptune Help song at [/SIZE][URL="http://www.neptunehelpsong.com)[SIZE=3] which explains the faulty door latch wax motor issue.[/SIZE]
