My Maytag washer jerks and moves accross the floor on spin cycle. I took the front panel off to check springs, they are OK. I found the motor to be loose and swivels freely with no way to secure or tighten it.
Is this normal
Is this normal
Check the bottom of the washer for white plastic shavings, if so, you have a worn snubber, a white ring on the bottom of the brake housing.
Rich,
Thank you for the reply.
Yes, there are white shavings in the bottom. Do you have an illustration of the snubber and brake housing?
Again, thank you for your time and expertise.
Found this online.
Any other advice?
This advice is for certain Maytag TOP LOADING washers equipped with a vertical transmission and drive belt system.
Loud squeaking noises during the wash cycle or, at the end of the spin cycle, can be attributed to a worn snubber ring and/or brake assembly. The snubber is a plastic ring located under the tub support. It helps to reduce vibration as the tub agitates and spins. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is located to get rid of some noise related problems (this will be the round metal plate where the tub support meets the bottom casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking of the washer when the spin cycle stops. If the corn starch tip does not get rid of the squeaks, I would recommend replacing the following parts:
Brake Stator
Brake Rotor and Lining
Snubber:
You will need: Brake Removal Kit*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs brake spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
The parts required to make the repairs aren’t very expensive, but the tool required to do it can cost about $100. This repair I would rate as DIFFICULT for the average do-it-yourselfer. If you’ve never worked on this type of washer before, this is not a job that I would recommend. However, Maytag DOES provide informative how-to instructions with all their parts.
To replace the snubber and brake assembly:
I hope you find these instructions helpful
DO NOT follow this proceedure. You do not need the special spring release tool and you do NOT need to remove the pulley.
Go to my sticky "Replacing Maytag Performa washer snubber" in the search box above. With Performa, the housing screws are long enough. Post results.
— Begin quote from richappy;185231
Rich,
I unhooked the springs, walked the belt off and unhooked hoses. I removed the tub assy and trans with pulley intact, removed the fabric softner cap from spindle and placed upside on the floor. I loosened all screws evenly and gently pryed the cover up to the screw heads. This created enough space to remove the old snubber, vacuum depris, install new snubber and tightened screws.
This took 1 hour if that, my Maytag don’t go for walks anymore!
Thank you;)
Thank you very much for the post! I appreciate it and after your relatively easy job, I will probably charge less for this repair. It seems obvious this repair is really not that hard if you avoid the hard and expensive way some recomend! Well done.
Rich, Thanks so much for the info. I replaced the snubber on my washer last weekend. As suggested, I took the entire tub out and replaced the existing screws with 1.5" ones ones to release tension on the 200 lbs spring. The six springs holding the tub at the bottom would have been very difficult to remove and put back on. But before removing the springs I inserted coins (quarters) into the spiral slots of each spring thus maintaining most of the tension at removal, which made it a lot easier to remove and put the springs back. You’ll need about 10-12 coins for each spring. My washer is much quieter now and doesn’t go for walks anymore. Thanks so much for this forum.
You are wellcome, I allways try to make a proceedure I write to be complete, accurate, and without unnecessary expense, good luck with this.
We’ll I’m back…our Maytag Performa has burnt up the replacement snubber I installed in November of 2010. The original lasted 9 years and the second one only lasts 3 years? I’m guessing I should have replaced other associated parts… should I have replaced the springs as well?
Thanks in advance for your feedback and/or experiences with this issue !!
Mark
Check the dome for pits, if ok, sprinkle corn starch on the dome to keep the wear down on the new snubber.
