Mydishwasher will not power on
I have tried unplugging it to make sure it was not the outlet. I am sure that is not the problem as the garbage disposal still works. Can someone please help me figure this out?
You will need to test the fuse and see if it is bad. The fuse is located on the control board. It should read closed or 0 for continuity. Here is the part number, as well as a link to the parts diagram page. Hope this helps.
[part]AP3178588[/part]
Control panel parts replacement parts for WHIRLPOOL KUDI01DLSS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Hi Jeff, I ordered this part on Sunday and it was delivered today (2 days later).
My husband swapped the parts thanks to your help and our dishwasher is now running again! We are thrilled to have found this site. I will let everyone know about appliancepartspros.com A million Thanks to you!
Sincerely, California Mommy
Your welcome! Thats Great!! Glad we could help!:slight_smile: :slight_smile:
I will also mention that the wiring was not replaced with the fuse.
Hello californiamommy. You will need to replace the fuse again, and this time replace the wires. They had a problem with the wiring harness, and that is why they send the new one to splice in. If you replace the wire harness and the fuse, you should be fine. If you do not replace the wires sent with it, it will blow again. Hope this helps.
Okay, so I guess we will have to order again and do it the right way. You have been so helpful. Thanks again!
Your welcome. Let us know how it works out!
