No high speed spin
My washer passes muster in the test mode and has no error codes but when clothes are added in any cycle it tries a few times but never speeds up and eventually ends with a tub of very wet clothes. Sometimes (not always) it will go to warp speed with an empty tub in extra rinse mode but never with any sort of load. All the wiring, grounds, and hoses looks fine. The pressure switch checks out with an ohmmeter and blow hose and I replaced the shocks for lack of a better idea. Could the CCU be bad? I’ve been trying to figure this out for a week now and the wife is going on the war path! Any advise would be greatly appreciated!!!
:confused:
Here’s some helpful video’s to diagnose. About 70% of the time on this unit it’s either the drain pump being clogged or the door switch fouling out. But it could be a CCU or MCU issue…try the easier fixes i mentioned first…the video’s should help you figure it out.
http://www.youtube.com/results?search_query=whirlpool%20front%20loader%20won’t%20do%20final%20spin&oq=whirlpool%20front%20loader%20won’t%20do%20final%20spin&gs_l=youtube.3...162559.175877.3.176260.93.49.29.12.22.2.287.5491.17j27j3.47.0...0.0...1ac.1.11.youtube.EF62Ey4mjBk
Thanks for the advise! After several attempts it gave me a MCU error, i cleared it and was able to make it fail again. Expensive failure for a newer machine but I’ll give it a try and post the results.
