[SIZE=3]Problem: Water getting to door dispenser, but not getting to ice maker, Model IM6.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]What I have done:[/SIZE]
[SIZE=3]Changed Water Supply valve-No effect.[/SIZE]
[SIZE=3]Ice maker inlet tube is clear – no ice blocking water flow.[/SIZE]
[SIZE=3]Freezer temperature -100 F[/SIZE]
[SIZE=3]Ice maker light is steady green-not flashing[/SIZE]
[SIZE=3]Feeler arm moves easily back and forth-no apparent problem with spring mechanism.[/SIZE]
[SIZE=3]Freezer door light switch OK. (Water stops flowing to dispenser when door is opened)[/SIZE]
[SIZE=3]Ice maker jump started (turned ice maker off for 30 seconds; Pushed feeler arm back and released 3 [/SIZE][SIZE=3]times in 15 seconds. No water flow to icemaker.[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Any ideas? I am about to give up the fight. Thanks.[/SIZE]
Swap the wires between the ice maker and the water dispenser coils on the water valve. Push the water dispenser lever and watch if the water will come into the ice maker. Post the results.
P.S. What is the freezer temperature?
