Oven temp varies from display temp
When I set the oven to 400 degrees, the actual insided of the oven is only 325 degrees give or take 10 degrees. Oven thermometer inside of oven also show 325. I have adjusted as per manual (with touch pad).
There is no error codes on the display. At one point the stove was popping, (like when the gas goes on to heat and during heat up). I have replaced nothing yet. Theres no more popping it just wont heat up as much as I want it to.
