The oven is very slow to heat up. The store-bought oven thermometer I put inside always says it is between 50-150 degrees lower than the set temp. Setting the knob higher used to make the temp spike, but now it seems to be just slowly creeping toward the correct temp. Thanks in advance for any help you can give me.
Related topics
Oven not heating to correct temperature | 2 | 986 | August 3, 2013 | |
Hotpoint Gas Oven | 1 | 634 | January 17, 2016 | |
Hotpoint too Hot | 1 | 2230 | July 13, 2010 | |
Does not heat to requested temp. | 1 | 872 | November 15, 2011 | |
Oven takes forever to heat up | 1 | 2168 | February 8, 2010 |
