we have a range, jdr8895aab… we had an electrical fire under 2 of the burner controls. We took off the range top and 2 or 3 of the white plastic square units under the controls, with 2 wires into and out of each, are burnt out. What are they and if I replace them, will this fix the reason they burnt out?
These are your ignition switches. They come as a 4-switch assembly. They often will short out if something liquid spills on the cook top and gets in under the control knobs.AP4009661
— Begin quote from magician59;287727
These are your ignition switches. They come as a 4-switch assembly. They often will short out if something liquid spills on the cook top and gets in under the control knobs.[part]AP4009661[/part]
My burner has 5 switches… Is there a set with 5?
This is the part listed for your model; and the parts breakdown diagram shows that you have five burners. So I think maybe there’s a hidden one in the bundle showing in the photo. It would be a good idea to confirm this with 877-477-7278 before making a purchase.
Hi, my name is Audrey and I am a Jenn-Air employee. I would recommend that you contact our Jenn-Air Customer Service department and they can assist you with the issue you’ve experienced. They can be reached at (800) 536-6247, M-F 8am-8pm EST, and Saturday 12pm-5pm EST.
