Thermador Pro Grand 30" Rnage Burner Light Stays On
I have Thermador Pro Grand 30" Pro-Style All-Gas Range with 4 Star Burners with the 2 XLO simmer setting.
All four burners work including the 2XLO simmer modes.
For some reason the Blue Burner light on the left side (XLO knobs) stays lit even when the range is fully off. I’ve tested all the features of each burner and they work.
Any ideas as to what is wrong with the range?
Hi.
The model number you posted doesn’t come up. Please check and re post.
Simon.
It’s about 5 years old now but this is the exact model:
http://www.ajmadison.com/cgi-bin/ajmadison/PG304BS.html
Unfortunately Thermador did not provide any technical information like the wiring diagram and/or parts list for this model. Whith lack of such information we are not able to help you with the troubleshooting.
Same problem. PCG36 two left XLO burners blue light constantly on. Both work fine no odor. un-plugged then re-plugged still on.
I have the same problem. did you find a solution? thanks.
