Thermador range sparking continuously
[SIZE=2]:mad: [/SIZE][SIZE=3][SIZE=2]My Thermador rangetop sparks continuously… nonstop, all-the-time. Sparks when the burners are lit and also when all the burners are completely off.
However, I can stop the sparking if I light the Rear/Middle burner (a non-XLO burner). When I have this R/M burner lit, all other burners light normally (including the XLO burners). Once I turn off the R/M [/SIZE][/SIZE][SIZE=3][SIZE=2]burner, [/SIZE][/SIZE][SIZE=3][SIZE=2]the sparking resumes even with other burners operating.
I have not observed any spark shorts, all the ceramics have been cleaned are are not cracked and the spark is strong.
I am scratching my :confused: head. Any ideas from the PartsPros?
Model: Thermador Professional[/SIZE] PRSE486GLS
[/SIZE][model]PRSE486GLS[/model]
Check the spark switch for this "Rear/Middle" burner (#164B on the [B]diagram[/B]).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232017
Gene. Thank you for the advice. I believe the switches are behind the control valves. However, I am not sure how to get to them. Do I need to disassemble the front panel? Or can I get to the back of the panel from the top somehow?
You do have to remove the control panel to access the switches. The instructions are attached to the reply.
