wheel bracket
Is the left dryer wheel bracket (AP2976087) adjustable?
The drum seems to be a little off in the back and I think it is losing a little heat. I was thinking of replacing the back seal it looks worn. The dryer wheels look fine but do you have to replace them often? Thanks Benny And Merry Christmas
Most likely there is an electric short somewhere in the cooktop and the circuit breaker tripped off. You have to have a simple multitester to perform troubleshooting. Also the model number you posted is incorrect. Verify and repost it, please.
maytag MAh 7500 washer will not tumble or spin. Worked fine until I replaced tub bearings. Not washing or spinning and sometimes get a "unbalanced load" message. Performed system check and alls ok. Continuity on unbalance circuit ok. Door closes and locks. Spin checks up to 1060RPM. Haven’t found any loose conections.
Any help with problem will be appreciated.
Tom
