Flame does not ignite. Ignitor did not glow so I replaced it with a new one. The new ignitor did not glow. The thermal thermostat and flame sensor tested closed on a multimeter,but I replaced the flame sensor anyway. Still no flame. There are two coils (2 prong and 3 prong) on this dryer. I got inconsistent readings on these (I tested with both a analog and digital multimeter). I am not sure if the coils have anything to do with the ignitor not glowing. Looking for some help. Thanks. JK
You may want to check for continuity the following parts:
The high limit thermostat - #43 on the [diagram](http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246710&diagram_id=28203702"]diagram[/URL],
AP3084674 -
The thermal fuse - #59 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246710&diagram_id=28203702),
AP3133489
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246710
