Whirlpool Dryer does not shut off and no heat
[SIZE=3]My dryer runs continously with no heat. If it has been stitting for awhile it will start the gas and flame up but after it runs for a short while the gas shuts off and the dryer continues to run. The timer runs on "timed" dry but not automatic. I replaced the timer (part# 3976584) but had the same result. There are three different thermostat / temperature controls I see in the parts breakdown, but not sure what should be replaced. Can you guide me in the right direction?[/SIZE]
i’m having the same problem and i was curious if u were able to repair it and if so what did u do/buy? Thank u.
