whirlpool icemaker wont make ice
[LEFT][COLOR=#000000]i have a whirlpool gd25dixhw02 fridge. the icemaker will only make ice when you pour water in the tray. i have replaced both control boards and the fill valve. you hear snoise like its filling but no water. i used a blowdryer to thaw rubber filler in icemaker. it still wont fill. when you open freezer door red light blinks twice then repeats. when you push in the door switch the red light stays on.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/497326-whirlpool-icemaker-wont-make-ice.html#ixzz24ne5GZ00
http://forum.appliancepartspros.com [/COLOR][/LEFT]
Hi.
Switch the plugs around at the water inlet valve and press the water lever at the dispenser. If the water starts filling in then it’s a bad icemaker. If you hear the water going some where but not in the icemaker trace the water line from the inlet valve. Make sure there is no breaks and the tube not frozen.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263299
Simon.
the tube seems to be frozen in freezer how do i melt it or replace tube
Hi.
The best if you can unplug the fridge for 12hrs with the doors open.
If you can’t afford it use the blow dryer but be careful not to burn anything.
Post the results.
Simon.
thanks for the help. i used a marinade syringe to put hot water through fill tube. i have ice
Very nice approach.
Simon.
