Won't start
Our Kenmore 90 series has been working fine, dries perfectly. On a routine, I keep the lint from building up inside and at vent area. Today the start button actuates the timer, but it will not start. I checked the door switch works fine. Just won’t start up. You can hear the start button "hitting" the time but nothing happens.
Hello,
Remove the bottom access panel and check the belt.
Remove the lint screen and the lint duct (under the drum). Check the thermal fuse for continuity.
