Really not sure how old the range is. I bought it used and when I got it home realized that the front right burner did not work. I replaced the receptacle and the burner and still nothing. So, I removed the back panel and traced all the wiring and everything was intact and none of the wires appeared burned or disconnected. So, I tested the infinite switch on the inoperable burner. Unfortunately, I do not have any sort of electrical testing devices; so, I tested it the old-fashioned way. I disconnected the burner wires from a working burner and attached them to the potentially non-working switch and the burner did not get warm. I then attached the non-working burner wires to a working switch and the burner got hot. So, by simple deduction I believe the switch is inoperable and needs replaced. Is my assumption correct and is there any potential for damage if I replace the switch if this is not the problem? Thanks for any help!
Related topics
GE Electric Range won't get hot unless you turn it way up | 4 | 1765 | January 11, 2010 | |
RF Burner low heat | 1 | 828 | December 3, 2010 | |
not heating | 4 | 800 | January 14, 2012 | |
Need Burner Wiring | 1 | 846 | January 26, 2010 | |
whirlpool range top not working | 2 | 866 | January 6, 2014 |
