Starting noticing a whining noise during spin cycle. Like a roller or bearing going bad kind of sound. The drum isn’t out of balance. Anyone troubleshot this before? Thanks
I would turn the spin basket by hand and determine the source of the noise. Usually bad bearings will give a sort of "rough" fealing and you will hear a rumbling noise. If ok, you probablu have something stuck in the pump. You can pull the hoses off it and check.
