2 lights flash but Maytag dishwasher doesn't.
Hello. I have a Maytag dishwasher model #MDB7609AWW2. Have had it for almost 3 years. The problem is that it will not start anymore. (yes there is power to it). When any button is pressed the "normal" cycle and the start button will flash but that’s it. I changed the control panel and it worked perfectly; but then on the 2nd attempt it started to have interruptions during operation. Now, it’s back to square one; lights flash but nothing happens or it can also occur that the lights don’t come on at all.(so I guess that’s progress in the wrong direction). Any advice would help and if you need more info just ask away, thank you
UPDATE: The problem was the control panel. Once that was replaced, the system worked fine.
