It stopped spinning and i replaced the clutch. It worked fine for a few months and now it wont spin again. Pump and agitator work fine. Im about to replace the clutch one more time. Any ideas on why the clutch is failing? Bearings look ok. The basket turns by hand.
Any ideas?
Did the old clutch have any oil on it from the gear box leaking?
Are you sure it’s the clutch again?
No oil on it last time. And I’m not sure if the clutch is the problem. The pads did not appear to have any excessive wear. I don’t have the new clutch yet so I have not taken the washer apart.
