4 prong to 3 prong cord replacement
I am trying to change my cord from a 4prong to a 3prong and i have a green wire that is in the cord itself and is labeled as the ground wire. I also have a green wire that is not connected to anything and is just there. The back of the dryer says that i should not connect new ground wire to the neutral cord. What do i do???
The water line to water dispenser is broke off inside of door. I want to replace line from bottom of door to dispenser connection. How do I get to this?
