This unit works fine but I noticed it has a 60-volt potential going to ground when the unit is not running. If I plug it into an ungrounded receptacle (without running it, of course) I get this 60-volt AC reading between the MW door the kitchen sink. There is no continuity between the ground lug and neutral or hot so I don’t think there is a short. Is this normal? If not, what would be the cause of it? Thanks.
Related topics
ground voltage 60 volts | 1 | 934 | June 26, 2009 | |
Frigidaire OTR not heating - advanced tests needed? | 1 | 1291 | April 12, 2017 | |
Frigidaire power issues? | 1 | 1156 | February 27, 2011 | |
Frigidaire microwave stopped heating | 2 | 2919 | March 29, 2014 | |
Missing grounding prong | 1 | 2153 | March 19, 2014 |
