The water dispenser inside the frig leaks. Will replacing the dispenser limit switch stop the leaking inside the frig? Is this hard to replace? Second, the ice maker is leaking small amounts of water in the back corner under the ice maker where the fill tube comes in from the back of the frig. How can I replace this or fix this leak. The ice cubes get frozen together.
Related topics
Amana Ice Maker Leak | 1 | 1746 | February 2, 2010 | |
Amana water line leak | 1 | 1009 | November 6, 2013 | |
Water dispenser leak | 1 | 1035 | June 13, 2011 | |
Ice maker is leaking water | 1 | 3895 | September 9, 2008 | |
water dispenser leaks | 1 | 723 | August 22, 2013 |
