Access to Replace a heating element
How do you gain access to replace a heat element?
I have been told to open the oven door and remove screws however this does not gain me access to the burner under the glass top.
Pull the range out of the wall and look for a screws on both sides of the range. Possible the control panel and/or side panels have to be removed.
