I’m trying to replace the clock module for a Frigidaire model FES388WECA Gallery Pro Series drop in oven/range. I have removed the visible screws that are accessible underneath via the oven door but the panel frame sits in a channel and I’m not sure/want to be careful not to break the cooktop in lifting or forcing the panel out to gain access to the clock assembly.
Any help on dis-assembly to get proper access?
Thanks!
