AccuBake Both Right Burners Stopped Working
I was having the oven perform a self clean, about 2 hours into it I heard a pop sound and my breaker for the oven was flipped.
Reset the breaker and oven came back on, restarted the cleaning process and after a little bit same thing happened.
Reset the breaker again and stopped the self clean. Now my two burners on the right side don’t work but left work fine.
I’ve done the following to try and figure out the issue.
Swapped burners from right to left and now they work fine.
Swapped the switches from right to left and they worked fine also.
At this point I’m leaning towards the wiring harness(?) from switch to burners or a fuse?
Thanks for taking the time to read my post.
