I have this Admiral dryer LNC7753A71 abt more than 10 years old. I could not find the model online maybe b/c it is too old. It was in very good condition until it made very loud noise like squeaky when i turned it on. I’m not sure what wrong w/ it. A friend of mine said that it was the blower wheel clamp. He tighten and glued it. It works fine for afew months and it started to make noise again.
Pls help. Thank you !
I also could not find any parts data using the given Model Number, but here are the parts for a LNC7766A71
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170321
Sounds like the glue job has let go, you probably need a new blower wheel.
Item 10 in "Motor & drive" section. You my also want to replace the clamp.
You will need a set of C-clip (sirclip) pliers to remove and install the the clip (Item12) or at least it will make this much easier.
From your description the blower wheel in the above unit seems the same. Give AppliancePartsPros a call or email to the parts people, they should be able to confirm that this is the correct part.
i have the same dryer, go to ************************.com.com and enter your model # for a full parts list with pics
