Dryer just stopped running. Won’t start. Light doesn’t come on. Tested outlet and it’s fine.
Is it an internal fuse or something?
Thanks!
Thanks!
Here are your parts, includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LNC7766B71
First I would check that there is power atr the unit’s terminal strip.
L1 to L2 should be 240 volts
If OK
Sounds like the thermal fuse (Item 5 in Section 4) may be blown.
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
