there were three wires on it, red connector, no connector and a blue connector…
I ran a jumper wire between the red connector one and the one with no connector… I pushed START and the light lights up until I release the start button.
So i jumped the red connector and blue connector wires, thinking theoretically, the dryer would think the door was closed.
I press start and nothing…
should my dryer have started?
I took apart the door switch and it does look burned out, so I will replace that… but how many more parts should I replace before giving up?
You may have jumperd the wrong two wires.
You would need to jumper the white wire to the
yellow one. If it dosent start then you need to do
some further electrical testing on the dryer.
You will need to know how to use a multimeter
in order to do that.
I say connector, but what I really meant was that the clip dealie on the end of the wire had a plastic "surround" on it to keep it from shorting against the other wires.
One of the surrounds was red plastic (the wire was yellow, had power when START is pressed)
The one that i said had no connector had no "surround" (grey wire, went to light bulb for inside the dryer)
and the Blue "surround" one was on the white wire (which was what i jumped to the Yellow wire to trick the dryer into thinking the door was "closed")
