agg help!
Hello. I have a side by side ge refrigerator. I noticed today that the power to the water / ice dispenser has stopped lighting up, and no water will come out, nor ice. It doesn’t even make a noise. Some how there is no power to This. THe light in the freezer and fridge is on. But its not cooling or freezing.
So the problem is although the fridge and freezer light up. It does not cool or freeze. And there is no power to the water / ice dispenser.
I do not hear any noise from the fridge at all. :cry:
Any help would be great
HI.
Most likely it’s a main control board went bad on you. It’s located at the back of the fridge behind the metal cover on the right lower part.
The control board WR55X10942
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210245
While you are there - open the compressor cover and clean the condenser coils on the right.
Thank you. Post the results.
Simon.
