I have a Kenmore 110.26902691 Model (Series 90) washer. Direct Drive Whirlpool made. It is making a grinding sound in conjunction with the agitation cycle.
In diagnosing it, the tranny/gearbox was shot (was agitating in spin)- and so I purchased a new gearbox and have installed it. My wife now tells me that for a week or two before it failed, the "old" installation with the old tranny was making a pretty harsh grinding noise in conjunciton with the agitation cycle.
Now with the new tranny, the spin and agitatation cycles now again both function, and the washer is washing "fine" (so I suppose the gearbox was indeed shot), but now when the washer agitates, there is a grinding noise (a deep/low grinding sound), that if one put there ear to the machine the grinding actually sounds like a low pitch rattle.
I’d like to eliminate that. Spin cycle is fine, no unwanted sounds. Drain sounds like the normal not-exactly-quite Whirlpool pump. Pump sounds OK. Motor - tranny coupler is fine (and had been replaced a few years ago), so it is fine and not really worn either. New tranny came with 1/2 of a new coupler as well.
Clutch looked OK to me, but I don’t really know what to look for. Brakes had a very slight drag if propelled by the brake/clutch cam engager, but that wouldn’t be the issue during agitation, which is the only time I hear this unwanted/unexpected grinding.
It doesn’t seem that for agitation there is even a bearing involved? Is there a particular method of lubrication that needs to occur on the agitator shaft, or between the shaft and the spin tube?
Any expertise welcome. I’m moderately mechanical, but I can’t figure this one out- I just haven’t seen enough broken washers (and don’t want to), but I have the money into this repair (and way too much time now- should have just bought a new one. I figured, how hard can it be.)
Any repair guys out there with a guess on the sound. Agitate cycle only, sort of a grinding noise in concert with the agitation moments. Agitation works fine (this is a two part agitator, bottom goes back and forth, top is an auger with dogs), both have seem to be working properly. But the noise is wrong.
Could this be the brand new gearbox? I hope not- but you never know. Given that the same sound existed on the old gearbox’s last days, I tend to think it is not the gearbox, but can’t figure it out.
Guesses?
Thanks,
MesaGuy
